Hello everyone! I'm stuck between two laptops. I'm not looking for a super-dooper laptop to play games like BF5 or Forza. I want something I can bring around and occasionally play games like Apex Legends or others... I'm also a student in need of a lighter laptop, as I have a G750Jm and it's a brick.I understand that I'm comparing a gaming laptop to a non gaming laptop, but what is the better choice? I've seen the 4k screen in person and it's pretty amazing, but the Rgb on the Scar 2 is just super cool to look at. Which one would you all prefer and why? Here are two laptops I've narrowed down to:
Dell XPS 15 9750: 32 GB of DDR4, i7 8750h, GTX 1050ti, 1tb PCI-E ssd, 4K touch screen.
Asus Strix Scar 2:  16 GB of DDR4, i7 8750h, RTX 2070, 512 PCI-E SSD, 144hz Non-touch screen.
Thanks!
( ͡~ ͜ʖ ͡°) ( ͡~ ͜ʖ ͡°) ( ͡~ ͜ʖ ͡°)
https://linustechtips.com/topic/1043497-tied-between-two-laptops/
if you want to bring it everyday to class the XPS will be your best bet but if you don't mind about slightly heavier laptop than the XPS the scar is not that bad if you dont mind about heavier backpack and not travelling anywhere on public transport. but if you are going anywhere in public transport i highly recommend XPS since if you going anywhere crowded you don't have to worry about your laptop getting crushed and the battery life will be a godsend in group task situation
TL:DR
-class first: XPS
-Gaming is important: Scar II
or if you want both but pay slight premium i recommend MSI GS65
https://www.amazon.com/MSI-GS65-Stealth-007-i7-8750H-Diamond/dp/B07MRG4JRB/ref=sr_1_fkmrnull_2?keywords=msi+gs65+rtx&qid=1552369601&s=gateway&sr=8-2-fkmrnull
it's slightly less powerful than the scar but it's has 2060 and slim enough and thin enough body to carry everyday
Thanks!
Hands down fast refresh rate screen and the 2070 the experience cannot be beat.
Memory & SSD difference can be upgraded any time.
Touchscreen, how many time will you use touchscreen?
4k on a small screen doesn't have any benefit, only if you use it close to your eyes, like a tablet.
1050ti vs 2070, that's a major difference, it's like toyota corolla vs tesla.
3 hours ago, Loch said:
snip
Budget? Usage? Preferred max weight and min battery life?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
TL:DR
-class first: XPS
I was looking at the msi gs65, only issue is that I can't find a gs65 with either a 1tb pcie ssd or a rtx 2070.
That's a very good point.
Budget is $2000 usd, max weight around 5lbs, and battery life isn't too important. I won't be gaming off the charger.
On 3/12/2019 at 8:59 PM, Loch said:
$2000 usd
2070 (no Max-Q):
CyberpowerPC Tracer III 17R Xtreme VR 800 / Eluktronics Mech-17 G1R (TongFang)
Clevo PB51EF-G
2060:
CyberpowerPC Tracer III 17R Xtreme VR 700 / Eluktronics Mech-17 G1R (TongFang)
Lenovo Legion Y740 15 customize
CyberpowerPC Tracer III 15R SlimVR 700 / Eluktronics Mech-15 G2 (TongFang)
Clevo P960ED
AW m15 - be aware of potential heatsink issue
1080MQ / 1070:
MSI GP63 8RF
Asus GX501GI
Desktop specs:
