First Build Review
Not gonna lie there's a lot I would change in this build.
Spec wise it is very overkill for 144Hz 1080p but you can get a 120Hz+ 1440p monitor down the road.
You are overspending in unnecessary areas and sacrificing your budget in important areas like your motherboard.
I added a far better cooler, a better motherboard, RGB ram that is only 200MHz slower which no person would ever notice ($20 cheaper), a cheaper and faster NVME m.2 drive, an excellent GPU that is $100 cheaper, a better case in every sense, IDK why you would go with an outdated full tower case. Also, don't get a garbage external hard drive, slower transfer speeds and they are nowhere near as reliable as 3.5" internal hard drives. Also added an equally as good PSU for $15 less.
