External GPU help
Go to solution Solved by blastreaper101,
2 minutes ago, DaviidEnzo said:
Hey y'all, I have a GPU already, my question is:
What is the cheapest way of connecting it to a laptop via USB C?
I'm thinking like, is there a cheap housing that doesn't require me to open up the laptop and connect it via the wifi connector?
Thanks ?
There's plenty of external gpu housing connecting via USB type-C if you google it you'll be surprise ;) ( I've never looked for it myself but I know there's a bunch of those, or you can simply wait until someone has some specific product to advise to you :P )
Thanks ?
https://linustechtips.com/topic/1041576-external-gpu-help/#findComment-12367818
