CPU running at 115°C
Pauze
I’m rather unsure as to what could be causing this. I’m pretty sure it’s either a CPU issue or a cooling issue. I am able to run games and recording with OBS at 250,000 bitrate without any issues whatsoever, however my CPU has been running at 115°C according to bios, and will run at that in bios. After leaving it off for a while it will gradually build up in heat but I have yet to see it surpass 115°C. I just replaced the thermal compound on my PC and that improved its preformance however it did not change the heating issue as far as I can tell. I’ve also noticed that my computer will blue screen when I open Google Chrome, usually giving me the stop code: “WHEA_UNCORRECTABLE_ERROR”
This PC is a brand new build that I put together at the beginning of February. Here is the parts list: https://pcpartpicker.com/list/dcmNhy
I will also add a photos of my radiator and the inside of my PC.
Thanks for the help!
double check your under-use temps using afterburner or another monitoring software.
I suspect the temp you're reading is the socket temp and not the cpu temp, but dear god if that is the cpu temp then absolutely stop what you're doing and shut down your computer because you're going to kill that cpu very quickly.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Pump probably failed....
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
It should be doing a tj max thermal shutdown right away as soon as it hits 105C
|King Of The Lost|
if it really is the cpu temp, then that is probably the issue.
I’ll look into it and reply. According to BIOS my temperature has been at 115°C, I don’t really want to boot my computer anymore, is there another way I can check?
How can I confirm/deny that it did fail?
Just feel the tubes or the block on your AIO. If there's vibrations from the tubes or you can feel liquid moving, the pump mostly likely isn't dead. If you don't feel anything, well, RIP.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
if you're sure your reading the cpu temp and not other component temps, then yeah. don't bother booting. as @KingCry your pump on your AIO probably failed.
Had the same thing happen to me only a couple weeks ago so its not totally unheard of.
Best way to tell if its the AIO is to Swap another cooler on and see if the temps go way way back down. If you didnt get a stock cooler because your got a k series cpu, then head over to a retailer and try to buy about the cheapest socket compatible cooler you can get, and give that a shot.
115C would have thermal shutdown your CPU already, but then Asrock has problems with this function on AM4 so maybe the same problem exists on 9th gen as well?
to test  whether the temperature sensor is working or not, try shutdown the system for a while so it gets cool, then turn it on while your finger touches the back of the socket without touching any components (i.e. finger directly on the PCB). If the CPU is at 115C then your finger should at least feel hot.
Desktop benching:
With the system on place your finger tips on the pump or a mechanics trick I use is a screw driver and place it on the pump and place the other end against your ear, we do it at the shop at my work to help isolate noise on pulleys when motors are running.
|King Of The Lost|
115C sounds like a broken temp sensor to me.
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
I booted it up to test and it is warm. My entire room has a sort of static smell to it now.
I couldn’t feel anything on the actual pipes(?) that connect the pump to the radiator however i could feel the pump vibrating a little.
Booted it up to try feel for liquid flowing so here is a better response
-snip-
The sensor for the board might be totally broken :c
If it is I couldn't recommend you continuing to use that board honestly and if your able to ask for an exchange.
|King Of The Lost|
Use the screwdriver method and I didn’t hear anything
Do you have another system that you can make a OS drive with? The fastest way is to get into Windows (could be installation from some other system) and use HWinfo's sensor mode (an app you have to download elsewhere). It shows all sorts of temperature sensors and can tell whether it's just one defective sensor.
Desktop benching:
I could, what do you recommend I do?
install a fresh OS into the new build's boot drive, create an account, download and run HWinfo's sensor mode (prove that it works), then boot into that with the new build, go to HWinfo's sensor mode, and read the temperatures.
Desktop benching:
Assuming it is, can I still run the computer until I get said exchange?
Probably not as they will want the board for testing to replicate the issue before issuing the exchange.
|King Of The Lost|
If I were to run it a few more times though it would have no effect on the other components though?
