Yes.
However you might need a bios update first for which you need a first Gen Ryzen CPU.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12353988
If you don't know how to update bios, safe solution is to buy B450.
But if you have access to people with the skill, like a pc service shop, you can ask them to update it for you.
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354007
It's not very hard, it just takes a USB stick and a YouTube guide
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354013
Keep in mind that if the board does not come with the correct BIOS, you will require an older 1st gen Ryzen chip and a GPU or a Bristol Ridge APU to update the BIOS. The B350 Tomahawk doesn't have any CPU-less BIOS flash capabilities.
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354035
That's where AMD's handy dandy boot kit comes in, and all you need is proof of purchase.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354036
2 minutes ago, cobatexe said:
Would you mind explaining the whole thing, like what the boot kit is, and stuff
So, on AMD's website you can have a CPU sent to you that's compatible with first gen motherboards, it's their cheapest CPU. Then, once you update the BIOS, they have you send it back.
https://www.amd.com/en/support/kb/faq/pa-100
See the bottom, short term processor loan. Although if you have a PC shop, it's probably more convenient to have them lend you a CPU. This isn't always the case, so I usually make people aware of the boot kit.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354064
Wow thats awsome
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354081
You really don't need to ask this kind of question if you have a service center nearby.
Getting the Boot Kit it's a long process.
https://linustechtips.com/topic/1039969-compatible-components/#findComment-12354089
