My current setup is a Lenovo motherboard, i5 4570, 16GB DDR3 1600 MHz, AMD RX580 8GB, 2x500GB SSD. I have $500 to spend. I can upgrade to an ASUS Prime X470, AMD Ryzen 5 2600X, 16GB DDR4 3200MHZ or I can buy just the RTX 2070. It is for gaming, but my CPU and ram are aging. Advice?
https://linustechtips.com/topic/1039680-upgrade-path-advice/
If you're going for high refresh rate gaming then upgrade the CPU. If you're going for high resolution gaming upgrade the GPU.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1039680-upgrade-path-advice/#findComment-12351835
You're going to face a bottleneck either way. I would just sit for the new Ryzen chips to come out and pick up one of those.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1039680-upgrade-path-advice/#findComment-12351837
7 minutes ago, Teddy07 said:
I have myself a i7 4790k and an gtx1070ti. cpu is still good and you do not have to switch so many parts. You could go for a used 4790k and buy a better gpu if you sell your old parts
btw which resolution and fps rate of your monitor?
4790k is fine with its 8 cores but OP only has 4 with his i5. You will bottleneck a 1070, nevermind a 2070. You would want to upgrade the CPU first to avoid a CPU bottleneck which would cause stuttering in games.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/1039680-upgrade-path-advice/#findComment-12351855
3 hours ago, LukeSavenije said:
wait, what?
4770k or xeon equivalent is a option too, would make a great combo with a 2060 or vega 56 for example
4790k = 4 cores/8 threads (has hyperthreading)
4570 = 4 cores/ 4 threads (no hyperthreading)
4790k can do 8 things at once, 4570 only 4. Makes a big difference.
https://linustechtips.com/topic/1039680-upgrade-path-advice/#findComment-12352447
eeeeeeeh, more or less. But yes, the i7 haswells have shown to be quite capable.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1039680-upgrade-path-advice/#findComment-12352507
