Question on fan types
6 hours ago, martward said:@Tristerin I am looking to buy intake fans by the way, not sure if that's important to note.
So I have about 20x 120mm random fans (Cooler Master, Corsair, Rosewill, Silence, and a bunch of no name fans) - A single Arctic P12 pulls as much air as 1.5 - 2 of those fans in use in any situation (radiator push/pull intake or exhaust). And at only .3 sone at max speed (sone is different than dBA - sone is like...how tolerable is the noise that its emitting - the larger the number the less tolerable to the human senses)
My Rosewill Nautilus case has a thick front filter (probably .125" thick) - prior to replacing with the Arctics I had to clean that filter about every 6 months to keep good airflow. I swapped out the Arctics...2 weeks ago? I need to clean the filter again (did it two weeks ago) or will have to in another couple weeks for sure.
I have to say, if you are going to BUY fans - I prefer bulk packs, pay now have when needed later so I can get a good price reduction - I REALLY like the performance for intake on the Arctic P12's. Ive seen the single fans on sale for 6-7$ each but the bulk pack on Newegg puts them @ $5.60 shipped to your door each (5 for $27.99 shipped)
I will be buying another case or two (P12's) when I get ready to do my custom loop in my gaming rig for all the fans in that rig.
For reference - I have bought the Cooler Master standard bulk packs, I got them for SUPER cheap on sale paid $2 per fan. None of those fans are in use now because the Arctics are easily twice the performance at the same sound level.
What is important to me is SOUND. I hate hearing my PC on. So for me I am recommending the Arctic P12's because they have a healthy mix of performance/cost/sound that meets my criteria's and are going to be my go-to's (until Noctua or Mag Levs become reasonably priced - it would take me over $200 in Noctua fans just to replace the fans in my personal rig)
