Try doing a soft reset on the phone.
https://www.technipages.com/reset-galaxy-s9
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1038475-s9-not-charging/#findComment-12341505
1 minute ago, YaBoiWill said:
The included cables from Samsung are a bit shite, mine stopped fast charging after a while.
Try connecting the cable from the wireless charger into it (assuming they're different cables?)
I have tried using 3 different cables. The wireless charging one, the original one, and one that I got from 5 below. The only way I can charge it is through wireless
https://linustechtips.com/topic/1038475-s9-not-charging/#findComment-12341534
Does it give you any sort of error when using a cable? My Note 8 will give me an "incomplete connection" popup if it isn't doing what its supposed to.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1038475-s9-not-charging/#findComment-12341545
2 minutes ago, Benjeh said:
lmfao.... try a soft reset when the charging port is probably full of lint...
Get a small needle or plastic, i use an old diabetic blood test strip on my S8 charge port, the amount of floor that comes out is silly. It stopping it from charging.
trie d it
https://linustechtips.com/topic/1038475-s9-not-charging/#findComment-12341559
Just now, SHG_Marsh said:
no nothing. I try to plug it in and just a black screen
Grab a push pin/straightened safety pin and see if there is any dirt/dust inside your charge port. I had that issue with 2 phones and simply picking it out with aformentioned thin piece of metal did the trick.
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1038475-s9-not-charging/#findComment-12341564
