Building new pc need help with GPU
Go to solution Solved by Guest,
If you can justify the extra cost, 2060 comes with more cool, but gimmicky technology
For a PSU something like a Corsair TX550M 80+ gold would be perfectly fine
For a case something like a Phanteks P400 or H500 from NZXT (they are both great options)
I'm building a new pc, but i havent decided on everything just yet. Most importantly the gpu. I'm still waiting for the gtx 1660 ti to hit my market and see the price. But i wanted to ask on your guys opinions on whats better. Prices for the RTX 2060 here are looking in between 390-510 euros depending on which brand etc...I'm estimating a price of around 320-340 euros for the gtx 1660 ti.
Currently the build is looking like this:
CPU: i5-9600k
COOLER: Be quiet! dark rock 4 or Scythe Mugen 5 rev.B
RAM: Corsair Vengeance DDR4 3200MHz 16GB (2x8) CMK16GX4M2B3200C16
MB: MSI Z390-A PRO
GPU: RTX 2060 or GTX 1660 ti
SSD: Samsung SSD 850 EVO 500GB(from my prev pc)
HDD: Seagate Barracuda 2TB 7200 rpm
PSU: ???
CASE: ???
Also which brand is the best of each respective card?
PS: for 1080p gaming
Thanks
https://linustechtips.com/topic/1038321-building-new-pc-need-help-with-gpu/
EVGA is a very good brand for the GPU. I would recommend them.
For the PSU corsair RMi, RMx, RM.
Case - any nice case that fits the budget... like the NZXT h500.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
The brand doesn't matter as much as some people may have you believe. Sure there are some slight differences, specifically in overclocking capabilities and some may have three fans and some may have two fans but underneath it's all pretty much the same. What monitor do you have and what refresh rate are you comfortable with playing at?
Don't cheap out on the PSU: https://linustechtips.com/main/topic/986897-psu-tier-list-30/
CPU : Intel Core i7 7700K w/ Noctua NH-D15. Motherboard : MSI Z270 Gaming Pro Carbon.
RAM : Corsair Vengeance LPX 16GB DDR4 3200MHz. GPU : PALIT NVIDIA GeForce RTX 2080Ti 11GB GamingPro OC.
Case : Corsair 600c Inverse ATX Full Tower. Storage : Samsung SSD 840 120GB EVO / Samsung 1TB HD103SJ / WD Blue 2TB WD20EZRZ.
PSU : Corsair RM850i 850w. Monitor 1 : Alienware AW3418DW 3440x1440 120hz Ultrawide. Monitor 2 : Asus VG248QE 1920x1080 144hz.
Audio : Sennheiser HD650 w/ JDS Labs 'The Element' USB DAC/AMP. Microphone : Satin Red Blue Yeti w/ Blue Compass boom arm and Blue Radius III shock mount.
Keyboard : Ducky One 2 RGB Cherry MX black custom w/ Red Diamond 550 Paracord coil sleeved USB type CMouse : Logitech G PRO Wireless.
ehhhhhhhh I guess, it really just depends on how well made the card was, too. There are brands that make really solid cards like the Asus Strix ROG OC, and EVGA's top of the line cards are really good, too.
There are brands that make pretty shitty cards so I would say it matters but one of the reasons EVGA gets suggested all the time is because of their customer service.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
@Acolyte Benq RL2455 60Hz
The 1660 ti or the 2060 will run well with that monitor for 1080p gaming but if you're looking to future proof (in case you decide to get a bigger monitor with a higher resolution) you may want to go with the 2060 or even the 1080 ti.
