yes you can, it's just a fan after all, attach it to the cooler and connect it to a header on the motherboard.
Personal Desktop":
Luna, the temporary Desktop:
As long as you make sure they run the same speeds, sure go wild.
11 minutes ago, steve1020 said:
ok great thank you for the response i was just scared that being the same fan on each side they would just pull air in the radiator instead of push pull.
Fans can be installed either way. If its wrong way, you just flip it around.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Make sure both fans are pushing/pulling the air in the same way, if not just turn out one fan, also theres "Y" splitter if you want to controll both fans at the same time
https://www.amazon.com/Rosewill-Splitter-Duplicator-Converter-Adapter/dp/B01N0XQ7XC/ref=sr_1_6?ie=UTF8&amp;qid=1550760466&amp;sr=8-6&amp;keywords=pwm+fan+splitter
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
