Other uses for Fingerprint Sensors?
Greenish
So Ya boi just got a new laptop and I noticed that it has a finger print sensor. The laptop is the MSI PS42 and the sensor is the Synaptics WBDI reader USB 086. I wanted to see if I could use it for anything else. I have always been one for high security. I was thinking extra security on certain files and apps. IDK I just want to use it for other stuff bc its cool. No judgeeees plz thnx.
idk tbh
Pretty sure you can 2FA lastpass with it for example.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I will take a look into that. I dont really use last pass but I will see if it is worth it
idk tbh
You can bind each fingerprint to an action, like launching an app. I used Lenovo fingerperint utility but I think it works for every brand
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
Whaaaaaat? That's crazy!
Does anyone know a good USB Fingerprint reader that I can use separately on a PC?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Check the latest (or the one before that) episode of handy tech
#BringBackLuke
