It is extremely odd for a motherboard to not have fan connectors. You're referring to these connectors correct?
Image result for 3pin vs 4pin fan
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1035045-fan-connections/#findComment-12311605
14 minutes ago, Premilix said:
Yes
I still find that odd, regardless, fan splitters do exist.
Up to 2 fans: https://www.amazon.com/JBtek-Black-Sleeved-Splitter-Converter/dp/B01EF9OI0O/
Up to 5 fans: https://www.amazon.com/CRJ-Blackout-All-Black-Splitter/dp/B0763FGH6S/
Up to 8 fans: https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B07N3HP8S5/
You can also look into a fan controller but those get expensive and messy quick due to a lot of additional wires
https://www.amazon.com/Thermaltake-Commander-Channel-Controller-AC-010-B51NAN-A1/dp/B00V80IQTS/
https://linustechtips.com/topic/1035045-fan-connections/#findComment-12311673
Thank you very much!
https://linustechtips.com/topic/1035045-fan-connections/#findComment-12311704
What motherboard / PC is this? You probably should invest into hardware controller which uses USB connector, if you aren't planning on changing motherboard in next 1-2 years.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1035045-fan-connections/#findComment-12311804
