Another one of these threads, right? I was wondering if a AMD Phenom II X4 910 would bottleneck a GTX 770 or 780, if I plan to upgrade some stuff later on. Just a little curious, is all.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/103474-will-it-bottleneck/
Oh yea. Most certainly. The Athlon X4 740 almost bottlenecks the 770, let alone the 780. Just imagine how your Phenom would be.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384253
yes but with some added oc its would reduce the oc
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384254
Yes it will. I have a amd phenom x4 965 BE and it bottlenecks 6870's in cfx. originally it ran with my 4890's.
CPU: AMD FX 6300 @4.2GHZ | MSI 970A-G 46| Gskill Sniper 2X4GB 2400| Samsung 840 EVO 120GB| NZXT Phantom 410 gunmetal|
Apevia 680W Iceberg| HIS R9-270X| WD green 3TB|
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384255
Would an AMD Phenom X6 1055t or something higher bottleneck?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384256
your going to want nothing less than a 8320 for that much graphics horsepower.
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384258
The 1055t might but bottleneck the 770, but probably wont.
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384262
All my stupid motherboard support are the lower end Bulldozer and Piledriver CPUs.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384263
Would a 760 be much of an upgrade from a 660 SC? Overclocked to the walls on both, of course.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384269
It would be an upgrade yes, but it won't be that noticeable.
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384280
well, 660 sli would be pretty strong upgrade, and cheapest, ofcourse there will be little bottleneck.
fact is, 660 is around 160 -170$, then you got 130 left that you can buy better cpu with. what is your mobo, am3 ?
psu?
Right now I have a crappy AM3+ mobo (Bulldozer/Piledriver, most Phenom/Athlon II's, 1 PCI-E x16 2.0 POS), and a CX430M.
I thought you were saving for a completely new rig have you decided against it?
No, just money is slow, and I'd rather have an "okay" rig for now and a kickass one quite a while later, than a piece of crap for now and a kickass one a little sooner than later.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1384502
Anyone who votes no or yes sint taking the question seriously.
Because it depends on what ressources an application needs.
Run crysis 2 in ultra 4k and you will have no bottleneck :lol:
99% of the time its a bottleneck though.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/103474-will-it-bottleneck/#findComment-1386235
