Hi, i recently got a new pc but i didnt have the money to get a good gpu for it, so i connected my gt 1030 gddr5 to it and im fine with low res and low setting for now but the problem is that my pc is automaticlly shutting off when i enter a game, like after a minute or somthing less. i tried to change the pc parts with my other pc like the gpu and psu and ram and cpu but i got the same results. i tried to my gt 1030 with my other pc and it worked fine.
the new pc spec:
r7 2700
be quiet 700W
asus rog strix b450 f
3000mhz vengence 16gb (8+8gb)
gt 1030
i just want to get a fix for now untill i get a new gpu
second pc spec:
r5 1600
corsair vs550W
asrock b450 pro4
3000mhz vengence 8gb (4+4gb)
gtx 970 gigabyte g1
https://linustechtips.com/topic/1034570-help-me/
the new pc spec:
r7 2700
be quiet 700W
gt 1030
second pc spec:
r5 1600
corsair vs550W
asrock b450 pro4
gtx 970 gigabyte g1
Just shutting down or reboot ? If the system is shutting down n rebooting during gaming it is most likely a power issue. Ur PSU might be failing.
My Rig
HP Omen 16 | 13th Gen Intel(R) Core(TM) i7-13700HX | 16 GB DDR5 RAM | NVIDIA Geforce RTX 4060 8 GB | 512GB PCIe Gen4 NVMe TLC M.2 SSD |
16.1-inch (40.9 cm) 1920 x 1080 165Hz | RGB Backlit Keyboard |
https://linustechtips.com/topic/1034570-help-me/#findComment-12307759
3 minutes ago, raswer4 said:
but i tried to put my other psu in the new system but i would get the same results
Do u experience shut down only while gaming ?
My Rig
https://linustechtips.com/topic/1034570-help-me/#findComment-12307792
Try connecting ur new components to ur old motherboard if u haven't done it already as u didn't mention swapping of motherboard. I had the random reboot and freezing issues few months ago. So I upgraded my PSU now everything is fine. That's why I came to conclusion that PSU is failing.
My Rig
https://linustechtips.com/topic/1034570-help-me/#findComment-12308391
i have swaped everything but i havnt swaped the cpu, like puting the r7 2700 in the asrock motherboard
https://linustechtips.com/topic/1034570-help-me/#findComment-12308633
but like i tried the gt 1030 in the other system and it worked fine with no crashes or frezzing just worked flawless
https://linustechtips.com/topic/1034570-help-me/#findComment-12308636
  • 2 weeks later...
Have you tried the new PSU in the other system with the card? Eliminate the PSU as a problem.
2600x, MSi B450-Pro, Corsair H100i, 32GB Patriot Viper Steel Series DDR4 3200, Corsair RM1000x, aData X6000 1TB NVMe, Samsung 860 1TB, Seagate 3TB x 2, Palit 1080Ti GameRock Premium, Silverstone GD08 Case.
https://linustechtips.com/topic/1034570-help-me/#findComment-12340403
can i ask a stupid question? why not use the 970 from the second pc in the new one? it's a lot better.
to answer the topic, have you checked the temperatures?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/1034570-help-me/#findComment-12340408
I see Corsair RAM there, in both builds. Are you using the latest UEFI versions on the boards?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1034570-help-me/#findComment-12340412
Just now, raswer4 said:
we are 2 here just waiting for having the money to buy 2 new rtx 2070s
Here are the forums you have to quote people so they get a notification of your response. Quote someone by clicking the arrow in their comment boxes by the + sign, caution sign, and the share button.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1034570-help-me/#findComment-12340420
6 minutes ago, raswer4 said:
ye with no problems
feels like a power delivery issue...though you might want to look at settings in UI... I know this will sound rude but was it definately seated correctly? I freaked out for hrs due to an RX580...to suddenly find It was seated against something that stopped it going all the way in
https://linustechtips.com/topic/1034570-help-me/#findComment-12340450
but my gt 1030 gddr5 is small factor
https://linustechtips.com/topic/1034570-help-me/#findComment-12340457
and i tried my gtx 970 in my new system with the new psu and it worked fine and then tried the gt 1030 in the old system and it also worked fine
https://linustechtips.com/topic/1034570-help-me/#findComment-12340460
but the thing is i dont want want the gt 1030 in my system cause i want the gtx 970 and the gt 1030 is my brother and we just want a fix until we get some money to buy 2 new rtx 2070s
https://linustechtips.com/topic/1034570-help-me/#findComment-12340465
Hmmm. Try reinstalling drivers, remove them first using ddu. If that doesn’t work, it could possibly mean the gpu could be broken. I’d try to get a rma if nothing else seems to work.
https://linustechtips.com/topic/1034570-help-me/#findComment-12340479
i tried it too but it didnt work. the gt 1030 works fine in my old system
https://linustechtips.com/topic/1034570-help-me/#findComment-12340570
Ah yes I did see you say that. This is a very odd situation that the 1030 works on the old system but not the new one, but the other gpus work fine on the new one. I’m at a loss of words. Try to see if it’s being seated properly? Maybe give it a little more force when putting it to 100% make sure it’s good in there. Not too much though :/
https://linustechtips.com/topic/1034570-help-me/#findComment-12340591
