Is overclocking to turbo speed overclocking?
Aljaz
can stock cooler hold turbo speed of cpu?
(from 3,6-3,9) do you consider this overclocking or just locking it to turbo speed?
Its overclock, look this , I had a 4790k 4gh 4,4turbo, Even at 4,4 steady thats like oc, maximum is 4,6-4,7 not so much room , so turbo is "factory" oc. Your turbo will depend also on thermals , not like when you lock it.
Case: Corsair 760T  |  Psu: Evga  650w p2 | Cpu-Cooler : Noctua Nh-d15 | Cpu : 8600k  | Gpu: Gygabyte 1070 g1 | Ram: 2x8gb Gskill Trident-Z 3000mhz |  Mobo : Aorus GA-Z370 Gaming K3 | Storage : Ocz 120gb sata ssd , sandisk 480gb ssd , wd 1gb hdd | Keyboard : Corsair k95 rgb plat. | Mouse : Razer deathadder elite | Monitor: Dell s2417DG (1440p 165hz gsync) & a crappy hp 24' ips 1080p | Audio: Schiit stack + Akg k712pro + Blue yeti.
If you run all cores at the all core turbo speed (PL2), I'd say that is not overclocking. If you run all cores at the single core turbo speed, that is.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Depends on the CPU. But most likely yes. If your are dealing with Ryzen you can probably go higher
If your CPU can do that speed on a board that doesnt support overclocking, then it's not overclocking. Otherwise it is, no matter if it needs manual intervention.
Desktop benching:
