help
Solved by minibois,
You can use PCPartPicker for this.
Just open a new parts list, select whatever part (whether it be a case, CPU, motherboard, etc.) and only parts compatible with that part will show up in the next part selection.
Some things you do have to double check, like CPU cooler height + case and such, but with those 'final questions', you can always consult the manufacturer website or you can ask on this forum.
