PSU being help captive...
Quote@Snotrap under Australian consumer Law, if the product has a major fault (such as your case) you have the right to choose either a repair, refund, or replacement.
With PC hardware, never get it repaired as you'll be waiting 4-8 weeks for it to get shipped to Asia, repaired, sent back. Go to the store you bought it from and request a refund, then you can buy a different unit if you wanted to.
Unfortunately 6 weeks is to be expected when sending an item off for repair. When they initially quoted you 2-4 weeks they were likely lying out of their ass so you wouldn't request a refund instead.
Send an email to the store you bought it from, tell them that the resolution they have provided for your faulty product is unsatisfactory and provide the timeline that you listed above and state that they have continuously failed to provide a resolution or communicate properly with you regarding the matter. Request a refund of the purchase cost of the unit.
