Uuuugh... Eating my Words. Note 8 Battery Drain.
SenKa
Linus has been mentioning sparratic battery drain on his Samsung devices since the S/Note 8 gen of phones. I was so confident that he was wrong to the point of out right doubting he was actually experiencing any anomaly with the device and simply used his phone more than he was used to. As a Note 8 owner myself, I was sitting pretty high in my own head that I was right.
Then my Note 8 begun exhibiting the same behavior Linus mentioned in his review of the Note 9. My battery is draining roughly 20% more each day than it did last month, and my usage patterns haven't changed. Unlike Linus, I have a warning from my Samsung device (shown by the Samsung+ app, something I would recommend he install on his to see if he has the same issue). It states, "1 Apps Are Using Battery. Security and Privacy."
Security and Privacy is a built in app, and one that will out right ignore commands to force stop or disable (it will re enable itself).
I've been putting off re-flashing my phone with a 3rd party firmware for some time now, because I never had an issue with the Samsung Experience. Is it now time?
I have tried restarting the device, clearing cache, every form of disabling the Security and Privacy app, and checking if the Samsung+ App was bluffing by uninstalling it. All to no avail. Ideas? Suggestions for a 3rd party firmware? I would like one that mimics the Pixel devices.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Yeah I started having this issue on my galaxy S7 back when I had that. Not sure why it drains so quickly. If you want what the pixel devices have, which would be stock android, I would recommend watching the video they did on that really inexpensive phone where they loaded stock android on it, they do a pretty good job showing how to go through that process. I believe the video is called pixel 3 killer or something like that.
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
Aight, thank you very much.
Useful threads:
Total: $1891.98
