Monitor brightness
BlackFireBG
Hi,I need someone's opinion about Monitor brightness.Is it good to choose 250 cd/m2 over 350 cd/m2 monitor?What are the differences and is it going to effect my experience?
theres no real opinions to be had, one can be brighter than the other, most the time monitors arent set to their full brightness by default unless you go into the settings and crank it
also depends if theres alot of light where the monitor will be, what panel technology and the general features of the monitor, but you wont find any issues with a slightly dimmer monitor
CPU: i5-4690k @ 4.4 GHz | RAM: 12GB DDR3 1333MHz | GPU: Sapphire Pulse RX 580 4GB
A 350 nit panel is obviously more bright than a 250  nit panel. 250 nits (250 cd/m2) is the typical brightness for a budget display.
But a 350 nit panel might hurt your eyes more than a 250 nit one (depending on how sensitive your eyes are to light).
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
