Hello, I need some help with my newly installed SSD. The problem I'm having is that the SSD is used 100% according to task manager when I either play a game which is a bit demanding or it's under a workload.
most of the time the problem is caused by System, i checked file location and it brings up an app in system32 called ntoskrnl. I could use the help
Some specs:
Cpu Intel i5-4440
GPU GeForce gtx 750
RAM 8gb
SSD Kingston A400 480gb
the pc is a bit outdated and I'm planning a new build.
https://linustechtips.com/topic/1031395-can-anyone-help-with-a-ssd-problem/
Is it actually causing an issue? If not, it could just be a faulty reading.
Primary PC:
PSU tier list
How many watts do I need?
I mean it's like the only thing i can see that's making the problem. Maybe there are some compatibility issues with the os and other apps, but that seems really unlikely.
it seriously just goes to 100% usage at random.
but what problem is it causing?
Primary PC:
PSU tier list
It's basically just completely freezing the whole system for a few seconds or sometimes fully just freezes to the point I have to restart the pc. And it's all because the SSD gets clogged by the System (telling by task manager).
