Using a TV as a Monitor.
Solved by SolarNova,
1 hour ago, Evreus said:Well, when i was using it with my laptop, the integrated graphics made it look ok. I was trying to see if there's anything like that since the integrated graphics was Intel and now im running a Ryzen 5 2400g with a 1060 6gb.
What ur trying to do is downscaling.
You can try to force your GPU to do the scaling but its unlikely to look much better.
Go into NVCP, go to "adjust desktop size and composition", then select perform sclaing on - GPU.
if it is already set at GPU, try setting to display, see which works best.
Chances are thuogh it wont look good, downscaling rarely looks good when looking at windwos desktop.
