First time build, need some help
the 2 fans, should the radiator be touching the case or the fans, also, how do i set up whether i want push or pull, and which should i do (Huge NEWBIE)
If your just going with 2 fans and want to maintain aesthetics then put the radiator against the case and the fans to the inside of the case, not on the outside. You dont want the hot air blowing into your case so look at the fans your using for some tiny little arrows on the side. one of the will point to the direction which the fan spins and the other the direction of the airflow. mount the fans so that they blow through the radiator and out of the case. this setup would be "push". I dont know much between push "or" pull but it will look better this way and you dont risk hitting the radiator fins and bending them if your working on your computer.
