sata power? 3 pin plug?
Go to solution Solved by gastew15,
^^ that's the sort of thing I want, im putting a raspberry pi in a case with some hdd's so I need power in there cant have a PSU as there is no 24 pin adapter :(
That solves the problem then right? Since the board it's self can be powered by really any microUSB cord, and you can get a small hub for the HDD and just plug the mouse into that one too..
I also don't know if  this is as good, but it's available in the UK  (USB 3.0 as well) http://www.amazon.co.uk/Anker%C2%AE-Converter-Adapter-Cable-included/dp/B006J2L0ZM/ref=sr_1_fkmr1_1?ie=UTF8&qid=1389871666&sr=8-1-fkmr1&keywords=Vantec+2.5%22%2F3.5%22%2F5.25%22+SATA%2FIDE+to+USB+2.0+Adapter+-+Model+CB-ISATAU2
alright guys I had a thought, is there such cable that there is a 3 pin plug to a SATA power? I could do with one? no PSU justa plug sorta thing?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/
no, you know sata power, for a sata hdd, the power that goes to that goes to a wall plug ??
}else{
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376621
No sorry I've never seen one
Also the wall voltage is 240/110 depending on where you live, you'd need some sort of power supply to step the voltage down
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376668
^^ I see what you mean grr lol my plan gone out the window
}else{
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376671
I don't think that's possible. Unless they somehow use 2x 3 pins and reduce some volts.. Since a 3 pin is Ground, 5 and 12 volt. While SATA power needs 2x ground, 3.3, 5 and 12 volts
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376672
I have a better plan.......
A four pin fan header to a molex which is then adapted to a pci e 6 pin how about that ?????
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376678
I think you said wall plug... If so..
I have an AC to DC adapter that reduces the voltage too, and turns it to molex power, then I hook up a small molex to sta adapter. VANTEC has a SATA/IDE to USB 2.0 adapter with all of that in it plus the data atapter for like $20 I think.
Product Link ($19 USD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376684
}else{
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376692
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376713
I agree i have those mini power-supplies to.
I  have GameServer`s And VOIP servers the only price is that you have fun on them.
https://linustechtips.com/topic/102933-sata-power-3-pin-plug/#findComment-1376730
