My modem/router is trash, please help.
ChetwodJ96
Howdy everyone, we recently changed ISPs at my house and they gave us the wonderful Zyxel 3415 modem/router combo, making the router I bought last year useless. My family is generally having zero issues with it, but I can't play on my PS4 Pro or Xbox One X without getting kicked off every ~15 minutes, sometimes more, sometimes less. After running a few connection tests (on the 5Ghz band on my PS4 Pro) band back to back, here's what it looks like
Dwn: 21.3Mbps    Up: 65.1Mbps
Dwn: 134.0Mbps  Up: 104.0Mbps
Dwn: 114.0Mbps  Up: 94.4Mbps
Dwn: 90.0             Up: 125Mbps
Dwn: 155.0           Up: 123.0
Naturally, now that I'm making this post it behaves miles better than it typically does, but it hasn't been uncommon over the last week to watch it drop to single digits and skyrocket to almost 200Mbps over WiFi and somewhere in the middle it boots my PS4 off. The modem/router isn't in a convenient place for me to run an Ethernet cable. I haven't suffered any problems on my PC or Switch on the same WiFi connection, but its difficult to even watch a YouTube video on either of my consoles if I'm taking that route.
Its already to the point where I want to just order a new one, as I play most of my games with my friends on my PS4. Any tips/recommendations are appreciated.
Can't you put the modem/router into modem only mode and go back to using your router?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
If you have a router you bought yourself, connect it to the ISP-s one and use it for Wifi etc.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I tried, but that pretty much crippled the speeds of the router.
You could go into your old router and turn off DHCP, and use it's wifi on a different channel to your mode,/router one, just connect it with the network cable, it' will then be basically operating as an access point... on some routers this is even an option in the settings.
Please make sure it's using a different wifi channel, as you'll get problems if not. When you say it crippled your speed, was your modem/routers wifi turned off? as that could make a big difference.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
