I have been a long time viewer of the youtube channel and i finally worked up the courage to build my first rig! Its a budget build and i came in under $800 with massive room for upgrades. I am still waiting on case fans but it posts with all hardware recognized. And i will post an after build with full RGB! Its just a Ryzen 3 1200 overclocked. Thank you for the awesome content on youtube!
https://linustechtips.com/topic/1028438-first-build/
On 2/1/2019 at 5:46 PM, Juniiii said:
Uhhhhhhhhhhhhhhhh get a 1600, a 1200 ain’t good.
1200 will be fine in the beginning. As he said there is room for upgrades and I guess he will upgrade the CPU anyway down the line. I'd wait for next gen ryzen to upgrade and stick with the 1200 for now.
https://linustechtips.com/topic/1028438-first-build/#findComment-12263648
