Boiling point of Jagermeister?
QuoteIf you mix 2 pure liquids, the mixture will not have 1 boiling point, it will actually have a temperature range between its saturated liquid and saturated vapor states, and each of them will be between the boiling point of the original 2 liquids.
To explain a bit more clearly, lets look at the example of pure water. Try it some time, if you boil pure water, as you continue to heat it, the temperature of the water will always be ~100 C (depending on atmospheric pressure where you are), why? Well, simple, liquid water cannot exist at temperatures beyond its boiling point. Any heat added to a saturated liquid contributes to its phase change enthalpy, which makes steam. The water itself will not heat up. Similarly, you can’t have cold steam (obviously), steam will always be ~100 C or more. There is one saturation temperature, meaning that liquid and vapor can only exist in equilibrium if they’re both 100 C. The saturation temperature does change with pressure however.
In a mixed liquid, that’s not the case. In a mixed liquid, let’s say water and ethanol (everybody’s favorite), Once you get the liquid to a boiling temperature (Bubble Point), it will actually continue to heat up as it boils. Eventually, you will reach a temperature where it will stop heating up, and it will only be boiling (Dew Point). However, each of these saturation temperatures is between the saturation temperatures of the two original liquids.
In short, it doesn’t work like you’d think it might, where you get to one boiling point and one part boils off then you get to the other boiling point and the other part boils off. That being said, they do boil off at different rates, which are based on their relative volatilities.
I'm not that great in translating what I learned in school so I googled it and someone was imo more capable than me to explain how the boiling point of two (or more) mixed fluids works. To summarize it's kind of a trajectory instead of 1 set temperature, so it'll start to boil as soon as it's hot enough for alcohol to boil but it'll continue heating until water is at it's max liquid temperature not counting all other stuff in Jägermeister for the ease of explanation. Because if you'd consider those and try to boil all liquid out of Jägermeister you would have just a messy residu of spices and such left unless you were to boil those as well lol
