I'm not here to help,
But I just wanted to say that that was a god damn roller coaster
this is what is left. an Old pentium which i dont know the specifics of.
and my Operon 6174 12 core. its full 692 mm^2 glory. rightfully on display on my keychain next to my Pentium. offcourse delidded.
i mean, this is all i have to show from my ld stuff atm.
edit: i think i might have missed the point of this thread OwO
and my Operon 6174 12 core. its full 694 mm^2 glory. rightfully on display on my keychain next to my Pentium. offcourse delidded.
thts so nifty o:
btw if u polish the lidded one to reflect the sun it could save ur life if u get stranded somewhere many helicopters are flying above!~ (an also u can show ppl u hav a survival tool made with real gold )
Just now, MicroDotz said:
thts so nifty o:
didtn have any polish on hand. so there is still some indium saughter on the CPU and the IHS. i thought about scrubbing it down to the point where i might would have been able to see the CPU cores, but i atm dont have access to fine enough sandpaper.
Protip: be careful when using a 3000*C blowtorch to delid. turns out the substrate doesnt like that.......
no need for it to be polished, my skin probably has a albido close to 1
LOL i think ima format my post a bit  -
hey wats the anime on ur pcs background? ? im tryign to finish tokyo ghoul s4 last couple eps atm~
also, i found a i5 750, its ona nifty p55d mobo with bunches of ram for 100, is tht cpu a piece of crap since its early gen or can i actually game with this do u kno?
Anime is "Housuki no kuni" or "Land of the Lustrus"
Great show. I really recommend it
Edit: dlnt drop it the moment you see 3D. This show uses it to its best ability in every way
ill give it a try, not usually an anime dropper but the style is wat i go by so depends if its an eyesore or well incorporated into modern anime styles ig, still unique is good~
thanks!
ps edited my main post!~
thanks!
It uses 2D animation when needed and 3D in general. Dont think youd ask for a better implementation.
There is literally nothing else that would have made the Gemstonegirls justice. Only pure raytraced 3D scenes.
cool i liek tht kinda anime, check out susei no gargantia if u are utterly bored one day in the future~
Your best choice in terms of systems would be a dell optiplex (or any office PC, offices, schools sells these or you can find them on the used market) with a core i5 3rd or 4th gen. (Make shure it has 8GB of ram or you will have to buy extra)
For about 150$ (ish)
Then grab a cx550 (2017) PSU from Corsair for 50$.
Then find a used R9 290x for about 80-90$ (ish).
Enjoy your 1080p high ultra world of tanks experience for about 250-300$ depending on the deals.
If you need a movie one day.
Kimi No Na Wa (Your Name)
Or
Padema inverted
Kimi No Na Wa id a must watch and both are visually and storywise alazing movies. Kimi no ka wa should have been the animation film of the year 2017, (its the general consensis) somehow it didnt get nominated.
And make sure to get one like the biggest one on this picture.
desktop-optiplex-7010-family-right-relat
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Or
Padema inverted
One really good movie is Koe no Katachi (A Silent Voice)
Some other PC's:
He allready has a tower he can use.
OP while you are at it. If you have the budget, throw in a 20$ SSD.
And also avoid inverted formfactoe Cases. (They have the motherboard on the left side when looking from the front)
Good romance last season:
Bloom into you
Its not for you if you dont like Yuri
Good sports anime 2 seasons ago: Hanebado
Its a badminton anime. Not for you if you dont like sweatdrops and is disgusted by that. It will ruin the action of that is the case
Ill be adding silent voice to my watchlist.
Sabagebu and Seitokai yakuindomo
Both silly shows. One with a lot of inuindos.
Then why did you recommend him to buy a Dell Optiplex if he already has a PC?
Or did you mean he has a case? As far as I know only the biggest one can be fitted to an ATX case, but it doesn't have normal front panel connectors.
Some other PC's:
He has a case.
Front panel connectors arent the biggest worry.
Im shure he can get some of the screwholes to fit. Though that is somewhat of a concern.
He might have to pick up a HP tower depening on what is selling around him.
honestly i looked into the optiplexies but theres so many models and the cpus arent allways listed on them, are they all a certain type of cpu?
and so didnt know how to narrow one down, i havent seen many cheaper ones as there sorta pricy maybe since ppl began using them for other things ?...
wat dyu mean schools sells them? ive gotten pcs from a trash bin at a college before but idk how to legit ask for dell optiplex lol
is there a model thats best too?
and about the i5 750,  it dosent seem to have integrated graphics so i guess itd be useless without a gpu installed alongside right?
Ask if they have older systems you can buy. Then check what hardware and offer failry. Doesnt need tol be optiplexes.
All you are really looking for is the motherboard CPU, Ram and HDD they come with. It doesnt need to be an Optiplex, but really any prebuilt with desktop CPUs and 8GB of Ram.
You can look for those seperatly if you want to. The key is that you want 3rd or 4th gen or newer
But many prebuilt PC's doesn't have a standard power connectors or motherboard size.
2nd gen CPU's are also good, they are really similar to 3rd gen.
Some other PC's:
Powerconnectors are usually similar.
He can go for either tbh. 3rd and 4th gen are just good for eyeballing.
On 1/31/2019 at 6:26 AM, MicroDotz said:
is 755 optiplex decent ? wat kinda processors can u swap into em?
Too old. It supports up to Core2 Quad Q6700
Looks like even some of the bigger ones needs an adapter like this:
https://www.amazon.com/gp/product/B01A210HKO/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=sl1&tag=dvznmedia-20&linkId=028c88e81e61b06b069dc7b7471eed10&language=en_US
Some other PC's:
♥ ty!!!evidently a 755 wont work
On 1/31/2019 at 6:40 AM, GoldenLag said:
It depends on the hardware inside.
Is it a core 2 duo system?
yus
