Intermittent Connectivity issues, possibly cold related?
Solved by Eastman51,
Well, I called my ISP. They looked at some logs on their end and the guy said that the cause of this is partially related to the cold weather, but is mainly a problem with either the coax cable and/or my modem. There's an issue where as the temperature drops, the outgoing signal increases in amplitude ("its nearly double the optimal spec" - the guy I talked to). The temp over the last 24 hours has continued to drop, and they guy said that our outgoing signal increased every hour. So because the outgoing signal is overpowering the incoming signal, my download speed is practically non-existent.
They are sending out a tech tomorrow to fix the cross-talk.
