4 minutes ago, Dimondminer11 said:
Don't ask why but I need the most performance possible out of a Pentium 4 540 (3.2GHZ 1c/2t 32BIT) for gaming. Any suggestions other than the make Windows see the 2 threads option which I've already done
I don't know how much more you can push an old prescott chip like that. I think those chips are locked so, perhaps, pushing the voltage up a bit higher. From what I remember their threshold is in the 1.4 range for voltage and OCin'g a single core CPU and getting it stable across 1 core shouldn't be terribly difficult. Pentium 4 540's don't turbo unfortunately : (
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1026723-i-need-help/#findComment-12239553
Just upgrade lol, any system running a cpu like that's is a potato. You won't be able to do much with a cpu like that
Do i Recommend Ryzen? Yes. All of the Yes.
Main Rig Specs - BIG BOI
Ryzen 5 1600 @ 3.9Ghz
ASUS Gaming TUF B450 Micro-ATX
2x4Gb HyperX DDR4 @2133
GTX 1070 Founders Edition
Corsair Crystal 280X
500Gb SanDisk Sata SSD, 1Tb 7200RPM Hdd
EVGA 500 Watt 80+ Bronze
EKWB A240
https://linustechtips.com/topic/1026723-i-need-help/#findComment-12239560
But howd I do that? The CPU is in an Optiplex GX280. I also have a 3.6ghz P4 chip but it won't work in the mobo.
https://linustechtips.com/topic/1026723-i-need-help/#findComment-12239566
I'm surprised you don't have any popped capacitors on that GX280.  That model is cursed.
For real, lol, I would just salvage the parts for another system and avoid that motherboard and power supply and case since it's Proprietary .
CPU i7 4960x Ivy Bridge Extreme | 64GB Quad DDR-3 RAM | MBD Asus x79-Deluxe | RTX 2080 ti FE 11GB |
Thermaltake 850w PWS | ASUS ROG 27" IPS 1440p | | Win 7 pro x64 |
https://linustechtips.com/topic/1026723-i-need-help/#findComment-12239809
