Yep. The connector type is known as C13 if that helps you search for it.
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12230127
2 hours ago, mariushm said:
Yes, you can use any power cable with the proper connector.
Try to buy one that's thick, look for a wire gauge that's AWG 18 or better (the smaller the number, the thicker the cable ?
not finding any such marking on amazon with cables:-(
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12230365
4 hours ago, Mahbub said:
can i use just any generic cable for  powering pc? i dont want to use the one that came with psu its too short. so what cable is safe to use?
Input is standardized. You can use whatever you want from the wall to the PSU.
From the PSU to the Board you have to use the ones that came with the PSU!
If you want to use a different one you have to check the pinout!
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12230528
On 1/25/2019 at 9:02 AM, Mahbub said:
india
Ok.  So India uses that funk three pin with the fat Earth ground, for starters.
Also, you use 230V mains, so wire gauge doesn't have to be as thick as other regions with lower voltage mains because W / V = A.
Seems like Amazon India is innundated with this "FENTICO" brand.  But if you scroll through the product listing to the "product descrption", you'll see towards the bottom that they're actually selling a 14g wire product.
So it seems like these are what you want....  just pick your length.  That is, as long as that's the kind of wall connector you have in your house and not a BS1363 (from British rule) or NEMA 5-15 (typically used in commercial and hotels).
https://www.amazon.in/dp/B077H6CKCW/ref=cm_sw_em_r_mt_dp_U_9tktCbD05ZY7G
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12234665
but the voltage it can carry is just 125 ?
https://www.flipkart.com/pac-3-pin-power-cord-cable-computer-monitor-printer-ups-pc-smps-3-meter/p/itmf7yyzj8z6rwyb?pid=ACCF7XFBXPQ3AZGY&lid=LSTACCF7XFBXPQ3AZGYXWOWEL
does this one seem good?
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12244349
11 minutes ago, Mahbub said:
No.
They're just saying that @ 125V it can carry up to 15A.  At higher voltage it can carry higher wattage.  A * V = W.  You're fine.
https://linustechtips.com/topic/1025605-psu-power-cable-issue/#findComment-12244378
