Possible problem with my overclock settings?
Solved by Spotty,
5 minutes ago, axido said:OH right
even if so though, impossible a 3930k beats it - these scores are way too low for a chip overclocked this much
RAM? Frequency & timings? Running it in triple channel? Single core OC or all core OC? Are the clock speeds staying steady throughout the test?
Difference with the 3930k could also just be generational IPC improvements from Westmere > Sandy Bridge.
Quick look at videos on youtube and it seems that X5680 stock is around 800cb, while 4.5GHz is up to 1000cb
