i recently got a xeon e3-1230 v5 mid tower server that has a 290w PSU i also got a evga gtx 750 ti.tho it is reccommened to have a 300w PSU.i saw people online running it on PSUS with less then 290w.when i plug in the gpu the pc starts up but the fans start spinning really fast and nothing shows up in the display.i tried this twice and only let it run for 15-20 sec cuz im not rly geeky in pcs and was scared by how fast the fans were spinning.should i keep it running,or is this a bad sign?and i should consider buying a PSU.also there was a flashing yellow light both times after i powered it down.imageproxy.php?img=&key=17c10421afdc6db8ive put a pic of the mobo and case.The Gpu does Not Require any connectors from the PSU.
https://linustechtips.com/topic/1023316-need-help-with-pc/
Being a server, the fan activity is normal. On bootup it will calibrate and check the fans to ensure proper operation.
The flashing yellow lights will be in some sort of pattern. What is that pattern?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1023316-need-help-with-pc/#findComment-12209583
