Website NOOOOOOOOB! help me :P
Solved by WanderingFool,
By the looks of things, you are not closing contenttext div containers.
e.g.
<div class="innerBox"> <div class="contentText"><p>-If you are prompted to run Java click "Run this time". A dialogue box will appear, click "I accept" Click "Run". <br> -It may take a few minutes to load, please be patient. </p></div><hr color="blue">
The </div> was the change I made (added it)
The closing tag will means that the rest of the content won't be nested together....just repeat the solution on the other contenttext containers you have and I believe you should be good
