Other ways to install RGB into a case other than RGB strips
A Lini
I have been looking at what case I should use for my build and decided to look at protocase cases and the benifits are worth it for me, but I do like RGB, and think RGB strips look ugly does anyone know any other ways to put RGB on a non RGB case, or am I just out of luck.
rgb fans are the most common. you can also get rgb memory, motherboard, and maybe some cpu coolers
On 1/17/2019 at 7:18 PM, A Lini said:
Thanks kinda forgot those exist
Motheboards have rgb, SSD’s like hyper x
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
thanks looked into it probably gonna get the T force RGB 1 TB SSD
Thanks the side pannels on my case do have enough room I think I'll do that
has anyone put nanoleaf RGB pannels on a pc, the case is going to be very big, so it might have enough space
Would be no different than on a wall, long as you can run the cabling necessary outside of the case.
