Performance pcs has everything you need.
Cant tell you to bend or not. They can both be done cleanly. Bending can take more time and material. Using fittings cost more and normally adds more resistance, which isn’t a big deal normally.
https://linustechtips.com/topic/1022605-watercooling-help/#findComment-12205144
Additionally, every fitting adds another potential point of failure. Chances are low for a fitting to fail when using good ones but it just is another added connection with a o-ring and o-rings can fail.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1022605-watercooling-help/#findComment-12206186
