So it's been 20+ years since I last gamed as a serious hobby. Now that I'm older the  learning curve is steep on the latest technology and my patience and time is limited. I currently have a nice NZXT i700 case (red), 1TB storage hard drive, and gtx 1080 ( Zotoc ) gpu. I anticipate being a casual to moderately serious gamer playing mostly FPS games. I Stream alot of video content. Also the usual many open tabs of stock sites, music, etc etc.. I did do alittle oc'ing back in the day but I'm not much of techie these days. So I"m ISO a great to best CPU/mobo/memory setup that will be kick ass on the games but will be a minimum of tinkering and no issues streaming video etc.
So can you guys chime in and help to end my migraine from researching and failing to come up with a solid combo....
Cheers!
https://linustechtips.com/topic/1020193-my-head-hurts/
A budget is helpful, but I'll throw some general recommendations your way.
If you're looking for streaming and gaming performance, can't go wrong with a Ryzen 7 CPU. Massive core/thread count per dollar, you'll only get a thread count match on the i9 9900k (and the majority of people don't really set their sights on that expensive beast, but if you can afford it then go for it.)
A quality X470 motherboard in the process range of $150 to $170 is a solid choice for both features and performance, so if you need something like more PCIe storage and USB ports, good board layouts, etc. then it's what you want to consider.
16GB of high speed ram is my recommendation, DDR4 3200 is quite nice to pair with Ryzen.
I see that you already have an HDD so an SSD would also be helpful for system responsiveness. (It's honestly not even a gaming PC without an SSD, I'm such an elitist I know;)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181389
Whaddup Rick.  How much do you wanna spend?
And at what resolution do you game?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181390
Hello Rick! welcome to the forums!
For gaming I would recommend either a i7-8700 Non-unlocked as it seems you don't want to bother with that: https://www.amazon.com/Intel-i7-8700-Desktop-Processor-Cores/dp/B07598HLB4/ref=sr_1_3?s=electronics&ie=UTF8&qid=1547238146&sr=1-3&keywords=i7+8700
For a mobo I would recommend a gigabyte B360M: https://www.amazon.com/GIGABYTE-B360M-DS3H-LGA1151-Motherboard/dp/B07BQ9SSH7/ref=sr_1_4?s=electronics&ie=UTF8&qid=1547238103&sr=1-4&keywords=lga+1151+motherboard
For your memory I woul go with  a 2x8gb set of corsair vengance ram: https://www.amazon.com/Corsair-Vengeance-3000MHz-Desktop-Memory/dp/B0134EW7G8/ref=sr_1_3?s=electronics&ie=UTF8&qid=1547238066&sr=1-3&keywords=ddr4+ram+16gb
If you have a higher budget You could go with a more expensive mobo but at the moment that should be a pretty good system.
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181403
SSD is useless for gaming
A black 7200 HDD is almost the same
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181409
Just now, MysteriousAeon said:
Except faster loading times on certain games.
Only when the game first load, after that the RAM is dominant
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181426
@MysteriousAeon @Constantin Guys let's not hijack his thread and make his headache worse.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181444
Game load times are irrelevant, you're saying?  Come on, I know you don't mean that.  Especially on heavily modded games or any that have loading screens ingame like MMO's or open world or games with levels, etc.
For streaming while playing, you want a high core count and at least 16GB of RAM as said above.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181447
There are many threads and videos out there, google it.
The difference between an SSD and a fast HDD in games is minimal, you will see a noticeable difference only when you launch the game
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181464
I've had massive loading time differences in Destiny 2 when I put in on my SSD. I have a WD Black HDD.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181472
I don't have to google it, I lived it.  When I moved all my games to a SSD from a HDD, I noticed load times drop significantly.  Ark went from 15 minutes to 5, thats worth it alone.  Everquest zone loading dropped.  All other games have initial load times dropping as well cutscene loading times drop, etc.
I'm arguing your point about SSD's being useless, when you then say they have a noticeable difference.  Even if it's only upon initial load, it's worth it.  But it's not just there, it's any time their drive access.  It's just a nice quality of life improvement.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181481
Anyway.... Personally i have 2 SSD's and i install my games on a black 7200 HDD Sata 3
Edit: Cause i have tried games in both and the difference didn't touch me
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181502
1 hour ago, IronRick said:
Also the usual many open tabs of stock sites...
Did you feel the need to reinforce that you're a grownup who owns stock?
No one here would judge you if you just wanted to game on your machine. It seems like over-compensating?
Unless you meant that you're a veteran gamer and just watch EA and Activision stock drop for the schadenfreunde?
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12181635
Oh crap, Ya sorry everyone.... Under 1k CAN  is my budget including a cpu AIO cooler.
Maybe use a high quality air cooler instead of liquid cooler for that budget, if you're concerned with value over looks. Be quiet dark rock pro 4 or noctua NH-D15 are superb performers.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12182120
I wouldn't because of what we know about the AMD Ryzen 3000 series right now, It'd be a waste of money, though its a bit away. And "normal people" don't need that anyway.
So its better to go for a mid range, cheapish 2600 and replace it in 6months, if the Board gets a BIOS...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12182527
I would recommend against AIO stuff because they are freaking expensive and not the most reliable thing.
So a good quality Noctua NH-D15 is making more sense. Especially since there is nothing that really goes wrong with the heatsink.
While it a daily occurance in this Forum that the CPU Temperature with an AOI suddenly is in the 90°C+ Area...
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12182541
-Thread cleaned-
Please keep comments respectful, on-topic, and contributing.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12182637
The new HDD I have was bought for storage. I well be acquiring a SSD for actual boot up etc.
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12183853
AIO for around $80 - 100? Not a good price/quality point?
https://linustechtips.com/topic/1020193-my-head-hurts/#findComment-12183942
