Gigabyte x370 K5
Ryzen 5 2600x
So the issue I'm having is when entering a manual cpu multiplier, the maximum vcore voltage I can get is 1.38v. It physically won't let me turn it up more. However if I leave the multiplier on auto, I can easily hit 1.6v vcore.
For example a multiplier of 4.2ghz will not go over 1.38v even with the maximum of +.204v added, but on auto it will gladly self boost to 4.2ghz with voltage spikes of 1.6v if I leave the vcore at +.204 (which nearly made me poo myself). Do you think I'm missing some setting or is this annoying gigabyte bored just being it's natural self? I cannot get 4.3ghz stable and I think it's because the board is not allowing enough voltage.
Adding pics of bios page in a few minuets.
https://linustechtips.com/topic/1019495-help-with-2600x-oc/
add more loadline calibration?
Desktop benching:
https://linustechtips.com/topic/1019495-help-with-2600x-oc/#findComment-12174604
I wish. No LLC support on this board. But can confirm, it's just gigabyte being annoying. I installed the ryzen master software just now, and though I cringe doing overclocking in the windows environment, ryzen master lets me hit 4.4ghz at 1.43v no problem. I hate this board, not going gigabyte again when x570 drops.
https://linustechtips.com/topic/1019495-help-with-2600x-oc/#findComment-12174643
1.43 is a lot...
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1019495-help-with-2600x-oc/#findComment-12174681
THIS IS SPARTA! But on the real, meh, if it dies it dies. I'm at 1.46 now trying to get stability. Long as temps stay good I'll let it fly. I've had this board and cpu long enough that I'm ok if it dies, rather wait for 3rd gen ryzen though. I gave up overclocking months ago because honestly the normal 4.2ghz boost is plenty for what I do, and this board hates overclocking. Rather the bios hates overclocking. Buildzoid says it's a decent board as far as build, but man gigabyte just missed the mark on overclocking support.
https://linustechtips.com/topic/1019495-help-with-2600x-oc/#findComment-12174726
I mean wouldn't you want the PC to hold out until Zen 2? It's not going to be for a several months.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1019495-help-with-2600x-oc/#findComment-12174732
