Problems with streaming
Go to solution Solved by mariushm,
nvenc uses hardware encoder on the video card which is separate silicon from the part that processes your game - so the 80% of cpu and gpu is used strictly by the game. Well, the cpu is still used to compress the audio to mp3 or aac, but that's basically something like 1-3% cpu usage.
So what answer do you expect... 80% is good, it means the game actually uses the video card well, same for the cpu... as long as there's no hiccups or stutters everything would seem fine.
6000 is ok, if you have the upload bandwidth to sustain it (you'd need about 7 mbps or around 800KB/s upload speed all the time).  The hardware encoder doesn't care about that bitrate, it actually has less computing to do pack the frames in 6000, would have to work more to squeeze in less bandwidth ...
Hey there!
I am currently looking at 2 builds I own:
 i5 6500
GTX 1060 3Gb
16GB ram ddr4 2666MHz
i7 2700K
GTX 780ti 2Gb
12GB ram ddr3
When I try to game on the i5 build it obviously runs a bit smoother, but when I try to stream for example Overwatch I get a lot of spikes on the i5 build (it's awful). On the i7 however things are so much smoother, it doesn't even feel like I am streaming. I get a little fps drop and the stream isn't laggy at all! I have no idea what causes this, maybe because the i7 has 4 more treads, hypertreading and 2mb more L3 cache??
I am using SLOBS for streaming btw :D
If someone could help me out that would be great!
https://linustechtips.com/topic/1019301-problems-with-streaming/
A 4 core 4 thread CPU is not going to cut it for streaming, You need those threads. The more, the better. The i7 is far superior in terms of performance for gaming/streaming over the i5 6500.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Also, SLOBS is horrible and buggy AF. It is also more resource intensive than just using OBS and a stand alone chat bot and such.
Community Standards
"Beast Mode"
Are you using the software encoder (x264) or the hardware encoder (nvenc) inside OBS?
If using the software encoder, then 2700k has higher clocks (up to 3.9 ghz) and has hyperthreading so you get 8 cores, and supports the same instruction sets (avx , sse4 etc) as the newer i5 6500
if you're using hardware nvenc, then the differences could be explained by you having only 2GB of vram memory on the GTX 780 - overwatch may change to using lower quality (smaller) textures on the gtx780ti, or shaders optimized for DX9 or DX10 instead of DX11 paths used on 1060 ... the game may have to shuffle fewer textures as you move through the open world instead of reading from hard drive and uploading in card constantly etc etc
I don't know, honestly never tried the game.
if you're using hardware nvenc, then the differences could be explained by you having only 2GB of vram memory on the GTX 780 - overwatch may change to using lower textures on the gtx780ti, or shaders optimized for DX9 or DX10 instead of DX11 paths used on 1060 ... I don't know, honestly never tried the game.
I tried nvenc on the i5 but also that doesn't work. The i7 is totally fine with x254
Thanks!
Do you got any recomendations for a upgrade, atm I got: H110M mobo, i5 6500 with 16gb ram 2666MHz......
Should try to get a "better" i7 or should I wait for zen 2?
2 minutes ago, Frosty! said:
Thanks!
with that board, the best you could get is the i7 7700. AMDs keynote should be kicking off here in a few minutes so we should know more about Zen 2 with that. Hold off on any changes/upgrades until then.
Community Standards
"Beast Mode"
I am also watching the keynote :D   If they have a great combo at my local retailers I'll just pick that up, but first we gotta see what we actually are getting!
Oh and is 2666MHz enough for a ryzen cpu, I heard you need minimum 3000..........
Hardware nvEnc should work on the 1060, you have your obs configured incorrectly. Check color format (should be NV12 I think), DirectX 11 renderer, yuv color space 709, full (for anything higher than 1024x768, yuv color space 601 for less, as it's considered SD content)
Software encoding (x264) will work on anything, you can play with encoding quality to make it use less cpu resources (so game has more cpu and gets more fps). Superfast profile will generally be good for those processors, ultrafast will reduce cpu usage by just a bit but with substantial quality loss.
Quote
If you have already the kit, then use it.
Ryzen does benefit from memory running at higher frequencies like 3000 Mhz or 3200 Mhz, you gain a few percent performance maybe with higher frequency ram but it's not really a "oh you absolutely must buy new memory kit"
I'll try that!
I'm now running a test stream and I got a ~80% load on the GPU and CPU with a bitrate of 6000. I switched to nvenc btw! Are these load alright or too much?
Alright then I'm good to go thanks a lot!
