How to click ok?
Go to solution Solved by Laniakea,
Solved, turns out phone has some thing for randomly enabling otg and data over usb.
Hi, touchscreen is not working, usb data ports are not working, otg is not working, only google assistant and can download apps trough Google play store on pc and it download that app on the phone. So I downloaded TeamViewer quick support and with Google assistant I opened it now I have to click the damn allow button and I'm stuck. What comes to your mind about solving this problem (puzzle)? I wish I had ADB over wifi or something, only Google assistant now I guess.
https://linustechtips.com/topic/1018961-how-to-click-ok/
some phones support USB OTG and you can plug a mouse on it with a USB-A to whatever charges your phone adapter.
Desktop benching:
https://linustechtips.com/topic/1018961-how-to-click-ok/#findComment-12169172
Usb data pins are I guess not working and Otg doesn't plug things only can power... I was using my mice before than and it stopped working over time.
https://linustechtips.com/topic/1018961-how-to-click-ok/#findComment-12169182
maybe bluetooth mouse works? But that's feeling like a hassle imo. Pairing could get you stuck too
Desktop benching:
https://linustechtips.com/topic/1018961-how-to-click-ok/#findComment-12169188
I already have a bluetooth KEYBOARD connected before but google assistant is shitty it doesn't connect for me I have to touch on it... And afterall it's a keyboard idk if it'll be any useful.
https://linustechtips.com/topic/1018961-how-to-click-ok/#findComment-12169199
I downloaded KDE connect app to both of my phones and now on the "well" phone it says devices on the network should appear here and the problem is I can't launch that app by the assistant because it has a rather complicated name compared to other apps, like I was calling the other app by saying "open quick support" and now idk how to pronounce KDE connect for it to open it. Is there a command to launch the latest application or something? It really pisses me off that a stupid bump on the road f**ks up ALL THE PROGRESS man.... Any idea will help thanks :)
https://linustechtips.com/topic/1018961-how-to-click-ok/#findComment-12169247
  • 2 weeks later...
