Low performance with GTX 770?!
Go to solution Solved by MegaDave91,
Yes, it is normal for it to not be a 100% all of the time.  Your system is also very balanced, so no worries there.
If you're surpassing 80 degrees, your 770 will throttle, meaning less performance. If you haven't already, set a fan curve so it does not get to 80 degrees.
Hey guys, this is my first post on this forum, so bear with me.
I am not sure if my EVGA GTX 770 is performing as should be.
Here are my specs:
i5 4670K - Stock clocks for now, and stock heat sink.
Asrock Z87 Extreme 4 MOBO
8GB Corsair Vengeance 1600Mhz RAM
EVGA GTX 770 Superclocked ACX Dual Bios - Stock clocks
Corsair CX600M PSU
Fractal Design Define R4 case
Acer 1080p 60Hz monitor - All games played at 1080p.
So i built this system a few months ago, but without the graphics card, as I was short for money at the time and wanted a working system so left out the GPU. I recently got my GTX 770, installed the latest Geforce Experience (with drivers) and thought I was good to go. I like to have constant 60fps in my games, and from what i had seen in benchmarks, thought this would be possible even on the highest settings in most of my games. However, when playing some games, I was dropping below 60fps (Far Cry 3, and Borderlands 2, for example). In more intense scenes, my fps can drop to around 30fps, but what confuses me is that when running Precision X, my GPU is only hovering around 50% load at all times. Even when my frames begin to dip, my GPU load stays around 50%, and sometimes goes even lower. The reason why I am concerned is that benchmarks I have seen show around double the performance I am getting in some scenarios. I know the results will be different for every setup, but i didn't expect such a massive difference (Same resolution, same detail level). I have tried many 'fixes', such as changing settings in Nvidia control panel (power management from adaptive to prefer performance), reinstalling drivers, turning on and off vsync, etc; and still the same results. So after searching on many forums, and trying many different methods of fixing the issue, I have come to this forum hoping someone will be able to help me.
I am really not sure what is causing this to happen. My PSU not having enough voltage? (The minimum for 770 is 600W, which is what my PSU is) My card being faulty? Driver issue? CPU bottleneck? This is all i can think of, but i thought my specs would be fine. My  CPU is at high load when playing games however (sometimes reaching 100% in borderlands 2), so maybe an overclock is needed.
Maybe this is normal, and I am just being paranoid, but  when i'm paying premium I like to know my items are working as they should. So if this is normal, some reassurance will be nice :)
So i guess to sum it up, my main questions are: Is it normal for the GPU to not be at 100% load all the time?
        Is there a bottleneck in my system? Is my card defective?
If more information is needed, please let me know.
Any help is greatly appreciated, and I thank you all in advance for your time.  :D
NZXT H440+ 2015 Edition (Black/White) || i7 6700k @ 4Ghz || NZXT Kraken X61 Liquid Cooler || EVGA GTX 980ti SC || 16GB Kingston HyperX 2666MHz DDR4 || MSI Krait Gaming Z170A Motherboard || EVGA 750W 80+ Gold Modular || Corsair M65 RGB Mouse || Kingston HyperX Cloud Gaming Headset (White) || Steelseries Apex Raw Keyboard ||  Acer XB240H 1080p 144hz 24'' GSYNC Display || Windows 10 Pro 64 Bit
https://linustechtips.com/topic/101842-low-performance-with-gtx-770/
Sounds like something is bottlenecking it? Maybe your CPU is overheating and throttling? Get HWMonitor, open it, run a game for a while, and report the max temperatures.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
what are the temps?
The temps are fine. Sitting around 50C at all times, havn't  seen it go any higher, even after a long session on Far Cry 3.
This is what i was thinking. The CPU?
Yeah. Look at how hot it's getting.
$200 Volvo 245
No, the 4670k is among the best CPUs for gaming.
That's good to hear. The  temps are fine, so it is not the cause. Thanks :)
Did you uninstall the Intel drivers?
Yes. This was done before installing the Nvidia drivers.
This is what i have heard, and hence why i chose it. The CPU is stable, and i'm pretty sure it  is not overheating, as it is at stock clocks.
Do a clean install of Windows 7 and it should be gone
Sorry, forgot to mention. I am using Windows 8.1. But a fresh install was going to be  my next move.
Are you choosing express installation when installing the graphics card drivers?
I did the first time. Then after reinstalling tried custom, and didn't select HD audio and 3D vision drivers.
check your graphics card frequencies.... sometimes there's a bug where the clocks can't achieve full load
The card is boosting to full clock speed as normal. ~1200 Mhz, but the usage remains at 50ish%
You just want PhysX and the graphic card drivers, and maybe GeForce Experience if you use it.
Have you configured your settings in the Nvidia control panel for maximum performance?
EDIT: I see you have
That is all i currently have installed. Same issue. :(
Tried that. No difference. Is it maybe normal performance for this card? It just seems to be lower FPS than other benchmarks...
Maybe I'm just  being paranoid?
So is the power supply not the bottleneck? I was worried that it might not be enough. Would i be safe overclocking with this PSU, or would i need mor watts?
