Return the AiO for a refund and grab a cheaper but equally performing air cooler? to me Dark Rock Pro 4 has made all other coolers obsolete, amazing performance, low noise and great aesthetics.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1018413-help/#findComment-12164406
Just now, Dissitesuxba11s said:
Just set the radiator in the front with the ML140's pushing air through the radiator. The front only allows for either 3x120mm fans or 2x140mm.
Can i keep the fans in the front as well or its not possible? The fans that comes with the case
https://linustechtips.com/topic/1018413-help/#findComment-12164425
17 minutes ago, Dissitesuxba11s said:
Not possible. The 280 rad only has holes for 140mm fans. You might as well take @Princess Cadence's advise if you want to use those fans.
Some people i have seen they replaced the front 120mm fans infront of the case with 140mm ones and they mounted the radiator behind those fans.
https://linustechtips.com/topic/1018413-help/#findComment-12164492
That's what I said earlier. You just can't use the 120mm in the front along with the two 140mm.
https://linustechtips.com/topic/1018413-help/#findComment-12164508
