Assassins creed odyssey low fps
JayBultee
my pc:
intel core i5 8500
8 gb ram 2400 mhz
asus prime b360ma
xfx fatboy rx 590 8 gig
samsung evo 860 500gb
my fps are really low, even on low i cant get a stable 60 fps,
wen i look up benchmarks on youtube they hit 60 fps on med to high with a intel 8400
does someone know what the problem is
Report_2018-12-31_17-43.html
Your ram i extremely low for this game and from what i have seen on Youtube videos, the ram have a big impact.
Assassins creed odyssey is one of the most demanding game and your pc specs are quite low for it.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
thank you, then i will buy more ram
I keep sharing this video but it's great for 1080p60 advise.
RAM might be an issue for you as stated above.
