Asthetics or performance
Solved by NineEyeRon,
Always simplicity for your first build.
Avoid RGB, AIO and other water/liquid cooling.
To save money avoid overclocking unless you feel a little brave or have plenty of cash, no point trying to build a budget OC rig.
For your first build stick to air cooling with a simple two fan in and one exhaust, this should end up slight positive pressure when GPU and PSU are factored in.
You can get a beefy air cooler and a OCing mobo and cpu. Try basic OC stuff and learn for your next build where you can step it up a gear.
