So I recently moved my PC (disconnected from power for a while), and now the "On" button on the case is blinking in sleep mode, I just want to know how to disable this effect.
The motherboard LEDs also reset to "breathing" but i disabled that in the BIOS, however I seem to have forgotten where to disable the power LED.
It really wouldn't be a problem but the LED on this case is bright enough to light up my entire room from under my desk.
Case: Cooler Master Masterbox 510L; Mobo: Asus Z270-p prime
P.S.- Sorry if this is more of a motherboard topic, didn't know which category was more appropriate.
https://linustechtips.com/topic/1014582-flashing-case-power-button/
You could always unplug the connector from the motherboard so that ti doesn't light up. I know it's not the most elegant solution, but it works, especially if you dont care if it's on when the PC is on
