HELP CPU clock speed stuck at 2GHZ than the original speed of 4GHZ
Solved by svgPhoenix,
Why are the sliders for only two cores enabled? This looks like something that needs to be changed in the BIOS. If you don't know what to change, just restore factory defaults and then redo any previous modifications minus changes to the CPU (hyper-v is fine tho).
Featured Topics
f23948 ·
Aleph256 ·
Posted in Storage Devices0 -
15
Bonznumber1 ·
Posted in Windows0 -
