Core Count Problem
Go to solution Solved by .Apex.,
4 minutes ago, Andromeda0161 said:
I haven't touched BIOS, by that I mean I haven't changed ANY settings. I booted my pc up after upgrade and that was it, my mobo is B450M pro-VDH fyi.
who knows maybe BIOS settings got messed up when you upgraded, so i suggest you go into your BIOS and reset your settings.
and don't forget to untick the MSconfig setting you set
So I believe some other people have had this problem before but I have not been able to sort the problem
I have recently upgraded my pc for the first time (Yipee) from an a6-6400k to a Ryzen 5 2600
However when i look at my core count in some programs, it seems i have either 1 or 2 yet i should have 6.
This was just a easy way of looking at my core count thingy (Minecraft)
This was on Device manager showing 12 cores/Processors
This was in "msconfig", and YES i did select how many cores, and 2 was the maximum ("Six-core Processor")
This was from CPU core parking, which shown 1 number of cores
This was from Task manager showing 1 core, and YES I did change the graph to logical processors
So basically non of them are showing 6 cores. I need help.
Thanks
https://linustechtips.com/topic/1013563-core-count-problem/
@Andromeda0161
it's actually showing 1 core and 2 threads.
are you sure you didn't mess anything in the BIOS? because you can disable cores in the BIOS, maybe try resetting it or look for that specific option
this is pretty weird because it's showing 12 threads in Device Manager
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1013563-core-count-problem/#findComment-12124524
5 minutes ago, syn2112 said:
@Andromeda0161
https://linustechtips.com/topic/1013563-core-count-problem/#findComment-12124547
https://linustechtips.com/topic/1013563-core-count-problem/#findComment-12124561
