slight crackling noise from behind my pc
benji_
when i go to plug something into the back of my pc, i can hear a slight crackling noise, presumably from my psu. it is a 1000w evga 1000g. i have only noticed this recently
is this normal since it is such a high wattage psu? full spec list is in my signature so you can get an understanding of what load i use.
ive had my concerns with this psu before:
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
sparks and crackling shouldn't ever come out of a power supply
just put me ear to the side of my case (not literally touching), and i cant hear it anymore, i doubt it'l stay this way since i noticed it a few days ago and it might just not be pulling enough load idk, currently on fallout 76 so my parts are being used
CPU: i7 4790k
Case: Dark Base 700
shit, gonna tag @jonnyGURU since he knows a fair bit
CPU: i7 4790k
Case: Dark Base 700
Sometimes that's a sound you never want to hear.
Other times that's just coil whine from the PSU and there's not much that can be done about it.
My PSU suffers from the coil whine. Been doing it for year. Have never had an issue otherwise.
Determining which one is your situation I can't say confidently.
i could hear the cracks on my phone, cant in headset. might be phone > facebook > youtube compression, no idea
CPU: i7 4790k
Case: Dark Base 700
phones died now, will charge it and try and get a better video tomorrow
CPU: i7 4790k
Case: Dark Base 700
What if could be is the lead going into the psu is not fully inserted. This happens a lot with extension chords and stuff to me, are you using the exact evga lead that came with the psu? (Perfect fit). Push it in a little (a lot) and see if it stops/worsens.
i am yes, ill push it more in the morning since im using the pc atm and dont want to lose power or get shocked lol. i moved my room around the other day and noticed the crackling then when plugging a wheel into the back usb ports. didnt like how it was so removed it to how i had it before and heard it again
CPU: i7 4790k
Case: Dark Base 700
Define "something".
The AC power cord?  Or something like a usb cable?
On 12/29/2018 at 4:02 PM, jonnyGURU said:
Define "something".
USB
CPU: i7 4790k
Case: Dark Base 700
Is your outlet grounded?
I assume so, UK standard.
CPU: i7 4790k
Case: Dark Base 700
On 1/9/2019 at 6:11 PM, jonnyGURU said:
Don't assume.
Test.
https://www.amazon.co.uk/dp/B078X6J5DX/ref=cm_sw_em_r_mt_dp_U_MKJnCbG2TY1Q2
Just because there's a ground pin on the plug doesn't mean there's an actual Earth ground wire behind the wall.
When i moved in about 5 years ago, the socket wasnt all the way on the wall. We had a guy come in and sort it but I dont know if he did anything to the electric itself or just re-fix it to the wall. Currently tryna pay the insurance on my car so can't buy that tester you linked, but will see if anyone I know has one
CPU: i7 4790k
Case: Dark Base 700
Don't assume.
Test.
i dont know if this is of anyhelp, but the first noise comes from an extension bar and the second is from the back of my xbox one s. this has been going on for a long time. it used to sound like a bad car alarm of siren and i couldnt figure out what it was. i thought the extension bar was broken so i bought a new one and it still does it. the old extension bar doesnt make the noise when plugged in to a different socket so could you help with this. thank you (if its not as clear blame youtube compression)
CPU: i7 4790k
Case: Dark Base 700
