Cpu connection problem
Go to solution Solved by mxk,
4 minutes ago, Trystan_19000 said:
i can find cables that go from 8 pin to 8 pin, 8 pin to 6+2, 8 pin to 4+4 but still none of these are exactly what i need, they all end up going into the bottom pictures configuration at one end
I don't know whats happening here, I think your power supply didn't come with the right cables.
it might be kind of hard to see but this cpu cable that came with my psu has two slightly different connectors on each end but both my power supply and my cpu power on my motherboard connect using the connector that is pictured on the top. is there a cable that has both of these connectors on each end? is my motherboard not compatible with this power supply or something? what should i do?
https://linustechtips.com/topic/1013015-cpu-connection-problem/
All connections with standard parts should be universal and compatible. I think one of the sides is specifically supposed to connect to the PSU/Mobo which should tell you which side connects to the others. I believe that the cable in the first picture connects to your power supply and the second, to your motherboard. Just try it out and you should find the solution.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120157
2 minutes ago, Trystan_19000 said:
I tried connecting the one in the first picture to my power supply, which worked, the my cpu which also worked but the connector in the bottom picture would not connect to either
So the top pic+psu worked, and the bottom pic+cpu worked? Is that what you're saying?
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120174
Just now, Trystan_19000 said:
no, the top pic+psu worked, the top pic+cpu worked and the bottom pic will not connect to anything
Where are you trying to connect it to? This sounds to me like its a PCIe (video card) cable.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120182
i'm trying to connect my psu to my cpu, i have other cables that have pcie printed on them but it looks like i don't have any cables that connect my psu to my cpu
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120236
It should be labeled CPU or something. Get out all of your cables and make sure you have everything. There should be a CPU cable...
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120252
the two pictures i posted are the ends of the cable labled cpu. i have another cable labled cpu but it has the two same connectors at each end and still does not work
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120261
lets see the motherboard you're trying to plug it into, and what port on the motherboard it won't fit into.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120271
i have everything installed so it might hard to see the connector (this was as close as i could get to it). the motherboard im using is an asus prime z390-a
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120287
i have everything installed so it might hard to see the connector. the motherboard im using is an asus prime z390-a
I have no clue how the top picture cable isn't plugging into this port. It has the right connector shapes and everything.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120297
So what I'm seeing here is that you need a cable that needs the same connections on both sides. It needs to be the top picture's connections but on both sides.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120346
yes, is there a cable like that? or do you know what the top connector is called so i can find a cable like that?
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120353
There should be since it's what needs to be plugged in for the PC to run. Its called an 8 pin EPS cable.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120358
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120410
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1013015-cpu-connection-problem/#findComment-12120428
