i7 2600k (not overclocked) bottleneck Radeon Rx 580 8Gb?
Here is a decent price on a motherboard, but it is used.
https://www.newegg.com/Product/Product.aspx?Item=9SIAFVV7EW5418
$125 with free shipping.
If you don't already pick yourself up a better cooler. A H212 will work just fine with that chip or maybe a H7. You should be able to easily hit 4.5ghz on that CPU via overclock... if it is a good chip then 4.8ghz for a daily driver is also a good option. I would start out just aiming for 4.5ghz as I don't really know any 2600k's that couldn't hit that range.
The only downside you will have with the 2600k is the fact it does not support pci-e 3.0, but unless you are moving to a very high end gpu this isn't going to be an issue. Pci-e 2.0 at 16x is equiv to Pci-e 3.0 8x. Which doesn't hamper most video cards more than a few fps on the high end.
I think the ultimate question is what is your current budget. If you have the budget for a full build then that might be the way to go. If you only want to spend the minimum amount then the motherboard now and saving for a new build in the next year or 2 might be your best bet. At the very least this will let you wait until the 7nm AMD products hit which I have a feeling will shake up the PC market and cause prices to come down considerably on consumer grade cpu's.
