So I am trying to export as a jar file.
When i build the jar. it outputs a 57kb jar file, which i assume is just empty.
What am i soing wrong? also, is this the right way to include txt files and stufd?
This is how my files are layed out
This is the artifact i want to build
I am here to learn, please correct me if im wrong or you see me putting bs on your screen!
https://linustechtips.com/topic/1011367-intellij-to-jar-problem/
57kB is pretty normal - it's compiled code, wtihout the JVM or anything. The source directory of a project I'm working on is about 280kB (which is more than yours looks to be), and the produced JAR, which I know to be complete, is 128kB.
I believe IntelliJ should include the resources too, but the best way to check is to rename the produced JAR to .zip (because .jar is just a .zip with a specific file layout), and open it in a zip viewer to check that it has the right files.
HTTP/2 203
this is very helpful.
I can run it, but nothing happens, it is visible in task manager as well.
Maybe it is running the wrong class ?
if you're running
java -jar path\to\produced.jar
it should run your application.Main class.
If you're trying to run it by just opening the jar, I would recommend running it from command prompt instead, so you get any error messages, and can also see when it finishes. I'm not running Windows so I'm not 100% sure if there's anything weird you need to do for it to work, but I think the command above ought to.
If you get a java.lang.NoClassDefFoundError, that means that either you're depending on a library that hasn't been bundled into the jar (if it's for a class that you didn't write), or that the JAR is wrong (if it's for a class you did write).
HTTP/2 203
if you're running
im not familiar with the windows cmd for navigation.
What libraby should i download to run the jar on linux?
Also, i changed it to a zip, and everything is present
My Properties file fails to load
this.input = new FileInputStream("domain/db/evaluation.properties");
This line is giving the error. Checking the structure and it should work no?
The relative path won't work, because the current directory is wherever you ran the command from, not within the jar. Instead, you need to use Class.getResourceAsStream, which will find the file in your include dir and open it as an InputStream. That code would become
this.input = Main.class.getResourceAsStream("/domain/db/evaluation.properties")
You'll need to make sure that this.input has type InputStream rather than FileInputStream for it to work.
HTTP/2 203
I found out about that. also my txt files were not in any sourcefolder.
How is it that we dont even learn in school about how to create a jar or how a jar is actually created by the system.
One last question:
Can write to txt files in my JAR-file. All i found on the internet were big NO's.
But our teacher wants to be able to run the program from a single jar, but i cant write in it....or can i?
tnx real much btw, u ave thaught me more then the whole semester of school did.
also I used 'getClass.getClassLoader.getResourceAsStream("...");"
Is that also good code ?
Partly because the way to make a JAR varies depending on what tool you use - I tend to use Gradle, which makes building a JAR really simple ("./gradlew jar"), while other people will use other build tools, their IDE (like you are) or the Java command line.
None of them are "best" - Gradle makes sense for larger projects, but adds a lot of bulk for a small school project - so there's not much point in teaching just one.
They could have told you how to access the files in the JAR, but often it can be beneficial to learn things like that for yourself, because it helps develop debugging skills.
One last question:
I've not used IntelliJ's JAR builder a huge amount, but on my project I was able to get the resources to be included by editing the artifact and clicking +, "Directory content", then selecting my resources directory.
Yup, that's fine. The only thing with that is that you are getting the class at runtime (using the getClass method) rather than at compile time (using Main.class), but for that it doesn't matter.
HTTP/2 203
